AutoCAD LT 2012 for Mac is no longer available on the mac app store. I downloaded it into a Mac Pro running Mavericks just a few weeks ago. Sadly it wan't compatable with Mavericks.
I am reinstalling Mountain lion on a spare drive just to make sure there are no other issues with ACLT 2012 in this Mac Pro and that Mavericks is the only problem.
I Like mavericks and wanted to be sure ACLT2012 worked on this Mac Pro before I ditch all the time I spent setting up the drive a few weeks ago. I am moving across the country to start a big project in 4 days. I need to be ready to go as soon as I arrive.
Where can I get a copy of 2012 lt for mac? The mac app store version has 5 liscences (I am using 4) and had no serial number. It also isn't transferable.
Thanks in advance.
Solved by wei503. Go to Solution.
As Wei mentioned in previous post - you need to login to MAS with your Apple ID, go to Purchases section and you will see the button INSTALL near AutoCAD LT application. I checked just now and was able to re-install AutoCAD LT 2011 from MAS:
BTW: according to Apple rules you can install applications from MAS on each Mac you own (not just on 5 machines)
Maxim
So will 2012 LT *never* be compatible with Mavericks? I find this incredibly ballsy on Autodesk's part. After paying 900 bucks and not even two years old, I can't use my software with an upgrade to the OS? WOW!!! And no path to upgrade to a version that doesn't have compatibility issues? I think Autodesk really wants me to move to another CAD platform ...
