AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD 2011 for Mac (Education): Problem creating an STL file
13 REPLIES 13
Message 1 of 14
557 Views, 13 Replies
I am trying to create an stl file. When I go to export and choose stl, no file is generated. I also tried In the top left of the Screen, changing 2D wireframe to Realistic, and then exporting. This time I got a dwg and not an sti. It is attached. Maybe that is what is supposed to happen, but I don't have next steps? Please advise. Thanks
Tags (1)
13 REPLIES 13
Message 2 of 14
maxim_k
Welcome to the Autodesk Forums!
There is no attachment in your post Smiley Sad
Do you absolutely sure, that you are using AutoCAD 2011?
What OS do you have on your Mac? A'm asking about this because AC 2011 is compatible only with 10.5.8, 10.6.X and 10.7.X
Plus with STLOUT you can export only solids and watertight meshes ("closed" meshes) from the drawing, all other objects will be ignored.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 14
in reply to: maxim_k
Thanks for the prompt response. I am using 10.7.x.
I don't know how to use STLOUT and I don't understand what "closed meshes"
are.
I'm working with a student and neither of us has used AutoCAD before. We
do have AutoCAD2011. We're trying to export as stl so that we can bring it
to the high school and use another app to render it for a 3D printer.
Can you talk to me like a beginner?
Sarah
Sarah Glatz
Technology Integration Specialist, RSU57
86 West Road
Waterboro, ME 04087
E: sarahglatz@rsu57.org
P: 207-247-3221 x2275
C: 207-329-1605
You can book me!
http://sarahglatzrsu57.youcanbook.me/
Message 4 of 14
maxim_k
STLOUT is the command for exporting STL files from AutoCAD.
And watertight mesh is AutoCAD Mesh object without holes in it.
Could you post here one of your DWG files you are trying to export to STL?
If you have troubles with attachments- compress DWG before attaching to the post.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 14
I attached it again 565KB - no problem.
Sarah Glatz
86 West Road
Waterboro, ME 04087
C: 207-329-1605
You can book me!
Message 6 of 14
maxim_k
Still - no attachment 😞
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 14
I don't understand, I can see it attached and the file size before pressing
Send.
I put it in my google Drive and shared it. Does this work? I can use
DropBox too if that is a better option?
https://drive.google.com/a/rsu57.org/file/d/0B-N7DmTaS4MNVVBxMk4zdkV5NzA/edit?usp=sharing
Sarah Glatz
86 West Road
Waterboro, ME 04087
C: 207-329-1605
You can book me!
Message 8 of 14
maxim_k
OK, got it.
Will look at it little bit later
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 14
maxim_k
I don't have AC 2011, but in AC 2014 I was able to export your DWG to STL file. See attached ZIP archive
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 14
Maxim,
I don't see an attachment.
Also, can you tell me how you did it so that I won't need to be dependent
for the next one? I realize it could be different due to the version
difference. But it might give me a clue.
Sarah Glatz
86 West Road
Waterboro, ME 04087
C: 207-329-1605
You can book me!
Message 11 of 14
maxim_k
Here is the attachment from my side:
I did it as usual, from menu File -> Export -> select STL file type from the list of file types, than give the name to the file, pick OK, select objects you want to export, hit Return.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 14
Maxim,
I still did not get your attachment. There must be an issue between your
mail and mine since you did not receive my attachments either. Can you
Google Drive or DropBox it to me?
Sarah
Sarah Glatz
86 West Road
Waterboro, ME 04087
C: 207-329-1605
You can book me!
Message 13 of 14
maxim_k
Try this:
http://forums.autodesk.com/autodesk/attachments/autodesk/520/11317/1/Ryan%20paper%20studies%20(1).st...
M
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 14
Maxim,
You are amazing. Thank you SO much. You've made the day of one 5th
grader. Hopefully we can figure this out for 2011 before he finishes with
the next piece.
Thanks again.
Sarah Glatz
86 West Road
Waterboro, ME 04087
C: 207-329-1605
You can book me!
”Boost
