AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Add hatches on Autocad MAC
4 REPLIES 4
Aleqc
20235 Views, 4 Replies
I have downloaded some cool hatches files (.pat) from internet, but I don't know hot to add them.
I DON'T KNOW ANYTHING ABOUT ADDING HATCHES, NEITHER WINDOWS NOR MAC, SO I NEED A GOOD TUTORIAL FOR MAC.
Thnaks
4 REPLIES 4
David_Stacey
in reply to: Aleqc
If you copy the PAT files into one of AutoCAD's support folders, AutoCAD should be able to find them.
To find your support folders, start AutoCAD and choose preferences from the AutoCAD application menu.  Click on "Application" on the left and then click the triangle disclosure next to "Support File Search Path".  You can even add a new folder if you want to keep your PAT files separate!
Another way to do this is to simply bring up the Hatch Library in AutoCAD for Mac, under the pull-down choose "Add Patterns" and then select your PAT file from the dialog.
Hope that helps.
Archrooy
in reply to: Aleqc
were did you get the hatch files to download from please?
maxim_k
in reply to: Aleqc
Welcome to Autodesk Forums!
http://www.cadhatch.com/free-downloads/4555343376
http://www.dotsoft.com/acadhatch.htm
http://www.cadcorner.ca/hatch.php
http://hatchpatterns.com/free_hatch_patterns.php
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: Archrooy
”Boost
