AutoCAD for Mac General
Active Member
Message 1 of 8 (372 Views)
Accepted Solution
2013 LT printers
372 Views, 7 Replies
04-04-2012 05:57 AM
I am trying this package and am having problems with printers. The package only sees the system printers consequently I am unable to make plots larger than the paper sizes they support (Tabloid). The windows version I have used (2011 LT) had drivers for DWG to PDF, DWG to DWF etc. which allowed me to select large sheet sizes in the layouts. I know that I can print to PDf using the Mac system but the largest paper size is limited to the installed system printers limitations.
Macbook Pro running Lion.
Am I missing something ?
I also posted this on the Autocad LT forum.
*Expert Elite*
maxim_k
Message 2 of 8 (371 Views)
Re: 2013 LT printers
04-04-2012 06:14 AM in reply to: jacksor1
In Edit page setup dialog (you can call it from Layout or Model) open Paper Size drop-down list, at the bottom of the list select "Manage custom sizes", click on "+" and select New or Select from list:
Edit the name of paper size (if you need), non-printable area, etc.
Click OK, your new paper will show in paper sizes list.
HTH
Maxim
Architect
MARSS
MacACAD | MARSS
Active Member
Message 3 of 8 (365 Views)
04-04-2012 06:46 AM in reply to: maxim_k
Thanks that will work.
I must admit I was hoping someone would just say go "here" for the missing printer drivers and have it all done for me, guess I need to open up my windows version and copy down all the sheet sizes and printable area settings.
Message 4 of 8 (164 Views)
01-08-2013 11:16 AM in reply to: maxim_k
I have the same problem and worked around to the same solution.  However, the preview of the PDF is always upside down.  Does anyone have any suggestion?
Distinguished Contributor
Message 5 of 8 (145 Views)
01-09-2013 09:16 AM in reply to: mzarchs
I don't have  a work around for the upside down pdf, but I am curious about your results with pdf.
Besides being upside down, is the  quality good?  Have you experienced any random cropping?
Message 6 of 8 (141 Views)
01-09-2013 10:31 AM in reply to: jacksor1
This only my second day on LT 2013 for Mac so I haven't a long history.  So far the PDFs seem complete once the orientation of the page is correctly established.
*Expert Elite*
maxim_k
Message 7 of 8 (139 Views)
01-09-2013 10:43 AM in reply to: mzarchs
Have you tried to play with this option in Page Setup dialog:
Maxim
Architect
MARSS
MacACAD | MARSS
Message 8 of 8 (136 Views)
01-09-2013 01:00 PM in reply to: maxim_k
Thanks.  I didn't see that the Page Setup Manager has a second half to the right that could be expanded.  Why hide it to begin with?  Thanks again.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
