anyone else having issues editing blocks / text after upgrading to OSX Mavericks? every other function seems to work properly, but when I try to edit blocks / text, I get the "Application not Responding" error. I've tried a fresh install which yielded no luck. I downloaded the trial version of 2014 LT for Mac and it seems to be running seemlessly, just don't want to upgrade quite yet.
any suggestions?
Solved by wei503. Go to Solution.
any suggestions?
Welcome to the Forums
This section of the forum is LT for Windows. Your best bet would be to post your question here AutoCAD for Mac
Howard Walker
We have delivered the Service Pack 2 Beta 2 version for both AutoCAD 2013 and AutoCAD LT 2013(non-appstore version) for Mac.
AutoCAD LT 2013 users can register via link below and get the update.
http://beta.autodesk.com/callout/?callid=5AC170CC43094C76BA5EB4B8A0DE1FED
Note: This LT update is not applicable for AutoCAD LT 2013 downloaded via Mac AppStore.
Wei
Hi ryan,
I want to inform you that Service Pack 2 (Beta 2) for AutoCAD LT 2013, which resolves incompatibility issues with Mavericks, available on beta.autodesk.com since this moment. You can use instructions from this post:
to login to beta.autodesk.com and find installer for this SP in Downloads section.
Maxim
Installed Mavericks today and service pack sp-2 Autocad Lt 2013,
Canoot openm any files with open file command, as soon as i click on a file to open Autocad shuts down. My partner ids having the same problem on her mac as well. Any ideas?
Mark
When will this solution be available to those who purchased through the Mac App Store? I'm beginning to feel like a real second-class citizen ...
I too have been having problems with AutoCAD LT 2013 for Mac since upgrading to Mavericks. AutoCAD contstantly crashes without reason or warning. Working on a drawing yesterday, AutoCAD crashed no fewer than ten times. I send the CER report each time it crashes (I've probably sent somewhere in the realm of 50 to 100 at this point) but I have yet to hear any response from the AutoDesk team. I've uninstalled and reinstalled AutoCAD; I've checked permissions on my machine; I've made sure that AutoCAD is the only program running when I use it; I've updated to Service Pack 2 through the "check for updates" selection within AutoCAD. I've also called a local reseller and asked if I could get a discount on AutoCAD for Mac LT 2014, since my existing program is essentially non-functional (you can probably guess the answer that I received).
Being a fair trade and local economy advocate, I've often lamented customer disloyalty and the new standard of low prices and low customer service, but it seems that AutoDesk has taken the concept unavailability to a whole new level; I've found it exceedingly difficult to find any way to genuinely engage with an expert who can help me with software issue (for whose time I would gladly pay). To be honest, if I had some type of assurance the same issues would not arise with AutoCAD for Mac 2014 or that, if they did, I could contact someone for help, I probably would have bought the program already. Tired and completely exasperated, I am posting to this community forum, hoping that someone else has had the same struggle and, perhaps, found a solution.
I think that the software developers at AutoDesk should be paid for their efforts and I do not support piracy, but after having this experience, I can understand why someone might install an illegal copy of AutoCAD, seeing as owning a legal copy does not guarantee greater software stability or greater access to customer support. I can especially understand it if these others, like myself, are hard workers of meager means.
I have had a good customer experience with SketchUp, so, without some type of resolution, I may focus my energy and resources on utilizing that program and its add-ons to produce drawings formerly created in AutoCAD.
If anyone out there has a similar experience or a solution, you assistance would be greatly appreciated.
-Matt
