• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    New Member
    there's a way to edit profiles, beams...???
    222 Views, 2 Replies
    12-09-2012 03:20 PM
    im From Brazil, and here we use Beams/profiles based on "açominas"
    theres a way to edit profiles, or add new ones
    im new on this software.
    plz help
    Please use plain text.
    Active Contributor
    Re: there's a way to edit profiles, beams...???
    12-09-2012 09:53 PM in reply to: dani_young
    I would recommend downloading the revit extensions from the subscription centre and use the generate content tool.
    _________________________________________________________________
    KarelCAD Application Support Specialist
    12-12-2012 12:15 PM in reply to: dani_young
    if you need a "quick" way, you can do a user profile, by drawing out the profile, then converting it.  When you convert it, it will prompt whether you want it local or not, if you make it local, it's for this drawing only.  Once you create it, it will be in your profile list.
    KP
    Kyle Pope
    Process and Power Specialist
    ECAD, Inc
    Our Blog
    www.pdoteam.com
