• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Valued Contributor
    solid foundations in ASD-Steele
    243 Views, 6 Replies
    01-10-2012 05:54 PM
    Why we should draw our foundations in separate file with ASD-Framework and then importing them in ASD-Steele 2012, i think it will be much easier if we have option to draw these elements directly in Steele module, so my suggestion is: if it's possible, autodesk developers to think about joining  theese two modules.
    Best regards
    Please use plain text.
    Valued Contributor
    Re: solid foundations in ASD-Steele
    01-10-2012 05:58 PM in reply to: ZHUKOV_ING
    Also the option for creating section cuts in formwork module is very very useful, in steel module we should create group and then we can create section cut.
    Best regards
    Valued Mentor
    ybogdanov
    01-17-2012 12:06 PM in reply to: ZHUKOV_ING
    one question, how do you import to steel? Recognize all information?
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Valued Contributor
    01-17-2012 04:53 PM in reply to: ZHUKOV_ING
    option is available  only  in ASD 2012 but first you should save your formwork drawing as acis solid in separate file
    Valued Mentor
    ybogdanov
    01-17-2012 11:41 PM in reply to: ZHUKOV_ING
    Could you said me the name of the option, please. I don't find it.
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Valued Contributor
    01-18-2012 01:28 AM in reply to: ybogdanov
    It's under tools menu.
    Valued Mentor
    ybogdanov
    01-18-2012 03:17 AM in reply to: ZHUKOV_ING
    But with this options the formwork don't recognize information. It will be only 3D solid, no? And if it's send to ROBOT don't recognize the formwork objects?
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
