AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
sheet set manager publish to pdf
4 REPLIES 4
Furneaux
676 Views, 4 Replies
I am trying to publish pdf via sheet set manager but obtain such kind result. Tables disappeared and limits cuts drawing
Autodesk Inventor Professional 2013 Service Pack 1.1 Update 1
4 REPLIES 4
Furneaux
in reply to: Furneaux
I have found something here but it doesn't tell the solution how to change print margins
Margin problems
http://forums.augi.com/showthread.php?135711-Margin-problems
lincannotbe
I also realized the disappearance of Tables since like 2013 version.
So bottom line I never use publish from sheetset.
One of so many bugs on this program.
maccad
I have the same problem, please let me know if you found a way around it.
Thanks, Lynley
Furneaux
in reply to: maccad
I have found the way to get drawing without cut limits, it is margins edit it pdf to dwg plot area. I have edit each sheet format. But the drawing remains uncentered
”Boost
”Tips
