AutoCAD Structural Detailing General DIscussion
Active Member
eknockolds
Message 1 of 5 (707 Views)
modifying connection templates
707 Views, 4 Replies
02-26-2013 04:57 PM
I am in the process of putting together a library of standard connection templates we would use regularly and am wondering if it is possible to rename, reorder and/or delete template connections once they have been saved in the template data base file? I have a couple of early attempts that have been poorly named that I would like to delete but don't seem to be able to do this.
Also it would be nice if it were possible to create different connection folders for a given connection type to help make the search for the correct template easier. Can this be done?
Ed
Valued Contributor
tony
Message 2 of 5 (668 Views)
Re: modifying connection templates
02-28-2013 04:22 AM in reply to: eknockolds
When you use an ASD macro and save away a variation of that macro the data is stored in an XML file which is in the folder shown below. I edit  the particular xml file and change the name their. If you could map the tCt entries to the dialogue for the macro you can create an entire macro using an XML file.
I make all of my user parts from the XML files and not the method provided within ASD. Once you understand it it's much quicker and far easier
C:\Users\???\AppData\Roaming\Autodesk\Structural\Common Data\2013
hope this is helpful Let me know if I can help further
Regards
Active Member
eknockolds
Message 3 of 5 (580 Views)
03-05-2013 05:29 PM in reply to: tony
Thanks Tony,
At least I can rename my connections to some sort of convention.
I'll give changing the tCt a go but looks to be a bit of a minefield for me.
Cheers,
Ed
Valued Contributor
tony
Message 4 of 5 (570 Views)
03-05-2013 08:27 PM in reply to: eknockolds
When you modify a macro and save it, It is save in the this folder C:\Users\???\AppData\Roaming\Autodesk\Structural\Common Data\2013 with a "UsrCon" prefix. Once you fild the XML file you can open it and then delete the entry you don't want of change the data to modify the macro you created.
Active Member
eknockolds
Message 5 of 5 (530 Views)
03-07-2013 03:24 PM in reply to: tony
Hi Tony,
Thanks for the advice, I was just saying that I am a bit reluctant to play with the tCt settings, but am quite happy to be able to change the name or even delete a whole macro if i want to.
Cheers,
Ed
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
