dear all
i am new to asd, i need to know how to add a plate connected to the beam in the beam assembly.
right now beam assembly is not showing the plate included in it even though i manually welded the plate to beam.
thanks
In the Model tab of the Object Inspector, right click on your group/assembly. You should see an option to "Add to group". Then just click on the parts that you need to be included in that assembly. Same for removing a part from an assembly.
See photo below.
I hope I helped. If this solved your problem click "Accept as solution".
