AutoCAD Structural Detailing General DIscussion
Valued Contributor
jorgeluisgdeaca
Message 1 of 5 (712 Views)
horizontal splice
712 Views, 4 Replies
10-09-2012 07:48 AM
Well, It's me again asking about tapered - 3 plates - welded plates (plate girder by ASD) both columns and beams.
I need a horizontal splice  beam to column (please see the atached).
If someone works with this profiles using this connection please help me because column (plate grider macro) only offers 3 plates+top splice and I need just 3 plates.
I've tried exploding and removing the splice plate without success.
Thanks in advance
Product Support
Jakub.Brozonowicz
Message 2 of 5 (708 Views)
Re: horizontal splice
10-09-2012 08:19 AM in reply to: jorgeluisgdeaca
Maybe you need to model column as a beam and the beam as column?
Any ASD model to share to check?
Jakub Brożonowicz
Valued Contributor
jorgeluisgdeaca
Message 3 of 5 (701 Views)
10-09-2012 10:35 AM in reply to: Jakub.Brozonowicz
Sure, This is an small steel building processing to construct.
It was designed with horizontal splices as in the previous picture.
I'm sorry I can't attach this file here because it has more than 6mb, please download from:
https://www.dropbox.com/sh/k83zdxqe1wjycnj/-XneHEpdLM
Bye
Product Support
Jakub.Brozonowicz
Message 4 of 5 (670 Views)
10-10-2012 04:43 AM in reply to: jorgeluisgdeaca
Look what I was able to do after switching beam and column.
Not perfectly horizontal splice but better than nothing.
Jakub Brożonowicz
Valued Contributor
jorgeluisgdeaca
Message 5 of 5 (661 Views)
10-10-2012 09:20 AM in reply to: Jakub.Brozonowicz
Jakub,
when I change column and beam locations some connections don't works as I was waiting.
If you look the attached some connections appears as "incorrect data" because it does not recognize them.
Any idea to solve it?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
