• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    Valued Contributor
    horizontal splice
    435 Views, 4 Replies
    10-09-2012 07:48 AM
    Well, It's me again asking about tapered - 3 plates - welded plates (plate girder by ASD) both columns and beams.
    I need a horizontal splice  beam to column (please see the atached).
    If someone works with this profiles using this connection please help me because column (plate grider macro) only offers 3 plates+top splice and I need just 3 plates.
    I've tried exploding and removing the splice plate without success.
    Thanks in advance
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: horizontal splice
    10-09-2012 08:19 AM in reply to: jorgeluisgdeaca
    Maybe you need to model column as a beam and the beam as column?
    Any ASD model to share to check?
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Valued Contributor
    10-09-2012 10:35 AM in reply to: Jakub.Brozonowicz
    Sure, This is an small steel building processing to construct.
    It was designed with horizontal splices as in the previous picture.
    I'm sorry I can't attach this file here because it has more than 6mb, please download from:
    https://www.dropbox.com/sh/k83zdxqe1wjycnj/-XneHEpdLM
    Bye
    Product Support
    Jakub.Brozonowicz
    10-10-2012 04:43 AM in reply to: jorgeluisgdeaca
    Look what I was able to do after switching beam and column.
    Not perfectly horizontal splice but better than nothing.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Valued Contributor
    10-10-2012 09:20 AM in reply to: Jakub.Brozonowicz
    Jakub,
    when I change column and beam locations some connections don't works as I was waiting.
    If you look the attached some connections appears as "incorrect data" because it does not recognize them.
    Any idea to solve it?
