AutoCAD Structural Detailing General DIscussion
Active Member
tkertesz
Message 1 of 6 (670 Views)
help files
670 Views, 5 Replies
05-11-2010 02:05 PM
Installed ASD typically and it says it cant find the help files. Whats up with that?
New Member
tswierkula
Message 2 of 6 (670 Views)
Re: help files
05-13-2010 04:45 AM in reply to: tkertesz
If you are connected to internet after press "F1" there will open a website with AutoCAD's help. If you aren't connected to internet you have to open "Options>Files>Help and...>Help File" and change to index.html.
Active Member
tkertesz
Message 3 of 6 (670 Views)
Re: help files
05-13-2010 01:44 PM in reply to: tkertesz
Thanks but I dont understand on how to change the index. Can you explain it to me? I am rarely online when using the program and would like to be able to access help.
Tom
Active Member
tkertesz
Message 4 of 6 (670 Views)
Re: help files
05-13-2010 01:53 PM in reply to: tkertesz
I actually got it to work.
Best regards and thanks again....
Thomas
Member
route1286
Message 5 of 6 (670 Views)
Re: help files
05-17-2010 06:32 AM in reply to: tkertesz
What did you do to get it to work? I am having the same problem.
Member
route1286
Message 6 of 6 (670 Views)
Re: help files
05-17-2010 07:03 AM in reply to: tkertesz
Autodesk's solution:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15068206&linkID=9240818
To disable online help:
http://www.cadforum.cz/cadforum_en/switching-online-help-in-autocad-2011-to-local-help-files-tip7289
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
