• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    New Member
    endplate-beam to column flange trouble (possible bug)
    461 Views, 1 Replies
    03-16-2010 03:28 AM
    In ASD (steel module), the "endplate-beam to column flange" connection does not work properly. After selecting a column and a beam, on the connection dialog box, the dimensions are not calculated correctly, the internal calculations for distanses are not being made and i cannot apply the connection to the model.
    After closing the window all other ASD/Autocad commands do not work and i have to restart the application.
    Any ideas?
    Please use plain text.
    New Member
    Re: endplate-beam to column flange trouble (possible bug)
    03-16-2010 06:45 AM in reply to: tromoskaifobos
    The problem was ocuring when i was trying to insert this connection to a new drawing, set in metric units. The "solution" i found, is first to insert a endplate-beam to column flange connection in imperial units, then to swich to metric units and insert the connection again. The .dwg file now has not this problem for the future.
    Please correct this bug
