• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Member
    RogerZimmer
    converting a revit model to ASD in order to add connections
    536 Views, 1 Replies
    02-09-2011 08:43 PM
    I have been able to export out of Revit a DWG file, which I can then open in ASD.  When opened in ASD the file(model)looks nearly the same as any DWG file created in ASD.  I tried to add connections, but nothing worked.  I repeated the process but only exported it as a ACIS file instead of a DWG.  I was able to create the file, but couldn't get ASD to open it. I have downloaded the ASD extensions.
    Can anyone explain what I am doing wrong?
    Please use plain text.
    Re: converting a revit model to ASD in order to add connections
    02-16-2011 07:44 AM in reply to: RogerZimmer
    Did you download the Revit extensions also?
