• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Member
    connection Circular non-vertical column and beams
    772 Views, 2 Replies
    10-02-2012 12:40 AM
    Hi I'm new in discussion group,
    my question is about connection beam-columns as in attached immage, the columns aren't vertical beams and columns are welded on connection How can I match or fit profiles?
    Please use plain text.
    Valued Contributor
    Re: connection Circular non-vertical column and beams
    10-02-2012 05:08 AM in reply to: albertopola
    You're traying to use "fit to object" macro?
    Member
    10-02-2012 07:18 AM in reply to: jorgeluisgdeaca
    I didn't blimp off "cut profile faces' projections"
    sorry, but thank you very much for your promptness.
    Bye
