AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
adding holes into plates in ASD
1 REPLY 1
RogerZimmer
1332 Views, 1 Reply
I am building a model in ASD consisting of HSS tubes and plates.  I have been able to cap the ends of the HSS with plates using the UCS and plate command in the modeling ribbon.
How do I accurately insert a hole in a plate?  I want to put the center of a 0.563" diameter hole exactly 0.75" inside two edges of a 4.25" x 2" x 3/8" plate.  My snaps only appear to attach to the work frame not the plate.  Apparently, I can't even snap a line off the corners of the plate, to locat the hole.
Any body have any ideas?
1 REPLY 1
edugarge
in reply to: RogerZimmer
Check out the screenshot I attached. It's from the steel manual of ASD.
After you activate the snapping options, you could use the hole's tools better.
”Boost
”Tips
