AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Z-profiles
9 REPLIES 9
Message 1 of 10
4722 Views, 9 Replies
Z-profiles
Where can I find/load Z-profiles into ASD database to use it as a purlins/girt profile?
Anyone know how to make connections between rafters/beams and laped Z-purlins?
Thanks.
9 REPLIES 9
Message 2 of 10
jad.dellel
You've to add SADEF database for example.
See the pic joined.
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 3 of 10
Hi Jad,
thanks for the reply and help me.
Do you have some standadr solution to connect purlins/girts with beams/rafters?
I've trying with a bended plate bolted in both sides.
Message 4 of 10
jad.dellel
the bended plate bolted in both sides is the good one.
Jad DELLEL
Message 5 of 10
in reply to: jad.dellel
Do you have another solution for this?
In the virtual event a few weeks ago Jack Johnson said to me that you have some videos to explain a bit more to use better these connections
Sorry but this a standard/automatic connection but I having problems to standarize this with ASD.
Please see in the attached.
Message 6 of 10
jad.dellel
The standard connection that I know near to what I see in your attached file is Purlin-rafter:
Select the macro: Purlin-rafter
Select rafter and press Enter
Select purlin and press Enter
Define connection
See the file joined.
Cheers,
Jad DELLEL
Message 7 of 10
Thanks Jad.
Now it´s clear.
Message 8 of 10
Sorry Jad,
I´ve  trying to connect a tapered beam to Z purlin but ASD dont recognozis the beam as a valid object.
In your example the hot rolled profiles are idetified as a valid member.
can you help me again?
Message 9 of 10
steve.driedger
Do you know if there is an Imperial database for Zee shapes?
Message 10 of 10
I'm sorry, many time ago I've moved from ASD to other programs that they are more flexible than this. I only use ASD for simple details.
”Boost
”Tips
