• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    jorgeluisg12
    Z-profiles
    1259 Views, 7 Replies
    05-10-2011 10:55 AM
    Where can I find/load Z-profiles into ASD database to use it as a purlins/girt profile?
    Anyone know how to make connections between rafters/beams and laped Z-purlins?
    Thanks.
    Please use plain text.
    Product Support
    jad.dellel
    Re: Z-profiles
    05-26-2011 04:44 AM in reply to: jorgeluisg12
    You've to add SADEF database for example.
    See the pic joined.
    Jad DELLEL
    Structural Engineering Product Support Autodesk, Inc.
    jorgeluisg12
    Re: Z-profiles
    05-26-2011 05:01 AM in reply to: jorgeluisg12
    Hi Jad,
    thanks for the reply and help me.
    Do you have some standadr solution to connect purlins/girts with beams/rafters?
    I've trying with a bended plate bolted in both sides.
    Product Support
    jad.dellel
    Re: Z-profiles
    05-26-2011 05:12 AM in reply to: jorgeluisg12
    the bended plate bolted in both sides is the good one.
    Jad DELLEL
    jorgeluisg12
    Re: Z-profiles
    05-26-2011 06:13 AM in reply to: jad.dellel
    Do you have another solution for this?
    In the virtual event a few weeks ago Jack Johnson said to me that you have some videos to explain a bit more to use better these connections
    Sorry but this a standard/automatic connection but I having problems to standarize this with ASD.
    Please see in the attached.
    Product Support
    jad.dellel
    Re: Z-profiles
    05-27-2011 04:33 AM in reply to: jorgeluisg12
    The standard connection that I know near to what I see in your attached file is Purlin-rafter:
    Select the macro: Purlin-rafter
    Select rafter and press Enter
    Select purlin and press Enter
    Define connection
    See the file joined.
    Cheers,
    Jad DELLEL
    jorgeluisg12
    Re: Z-profiles
    05-27-2011 04:55 AM in reply to: jorgeluisg12
    Thanks Jad.
    Now it´s clear.
    jorgeluisg12
    Re: Z-profiles
    05-27-2011 08:48 AM in reply to: jorgeluisg12
    Sorry Jad,
    I´ve  trying to connect a tapered beam to Z purlin but ASD dont recognozis the beam as a valid object.
    In your example the hot rolled profiles are idetified as a valid member.
    can you help me again?
