AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Z-profiles
9 REPLIES 9
Message 1 of 10
4727 Views, 9 Replies
Z-profiles
Where can I find/load Z-profiles into ASD database to use it as a purlins/girt profile?
Anyone know how to make connections between rafters/beams and laped Z-purlins?
Thanks.
9 REPLIES 9
Message 2 of 10
jad.dellel
You've to add SADEF database for example.
See the pic joined.
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 3 of 10
Hi Jad,
thanks for the reply and help me.
Do you have some standadr solution to connect purlins/girts with beams/rafters?
I've trying with a bended plate bolted in both sides.
Message 4 of 10
jad.dellel
the bended plate bolted in both sides is the good one.
Jad DELLEL
Message 5 of 10
in reply to: jad.dellel
Do you have another solution for this?
In the virtual event a few weeks ago Jack Johnson said to me that you have some videos to explain a bit more to use better these connections
Sorry but this a standard/automatic connection but I having problems to standarize this with ASD.
Please see in the attached.
Message 6 of 10
jad.dellel
The standard connection that I know near to what I see in your attached file is Purlin-rafter:
Select the macro: Purlin-rafter
Select rafter and press Enter
Select purlin and press Enter
Define connection
See the file joined.
Cheers,
Jad DELLEL
Message 7 of 10
Thanks Jad.
Now it´s clear.
Message 8 of 10
Sorry Jad,
I´ve  trying to connect a tapered beam to Z purlin but ASD dont recognozis the beam as a valid object.
In your example the hot rolled profiles are idetified as a valid member.
can you help me again?
Message 9 of 10
steve.driedger
Do you know if there is an Imperial database for Zee shapes?
Message 10 of 10
in reply to: steve.driedger
I'm sorry, many time ago I've moved from ASD to other programs that they are more flexible than this. I only use ASD for simple details.
”Boost
”Tips
