• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    Valued Contributor
    tedmail
    XREF issues
    298 Views, 2 Replies
    07-11-2012 09:27 AM
    I have been using ASD for two releases (now with 2013) and it still does not handle the XREFs well at all.  It will always have issues keeping the xref in the file if I close and open.  I must detach and xref all over again every time I open the file.  The autosave and save functions produce an error, but doesn't crash.  But if I try and modify an xref in place, all hell breaks lose and it crashes and destroys the file I have the xref to.
    Any ideas?
    Please use plain text.
    Valued Mentor
    ybogdanov
    Re: XREF issues
    07-16-2012 02:27 PM in reply to: tedmail
    any solution from Autodesk?
    Up!
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
    Valued Mentor
    Rich.O.3d
    Re: XREF issues
    09-20-2012 06:42 PM in reply to: tedmail
    similar issues
    when xrefed, an error randomly occurs which fails all the profiles and leaves just a stick model
    reload sometimes fixes, but usually have to detach - reattach
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
