Hi
I have been evaluating ASD 2014 for a while now and the proble that I have is that when I create a GA view of the structure the grideline or axes of the workframe that is displayed in the model space doesn't appear in the layout.
I'm not sure what I'm doing wrong. When I create the workframe, I select the option "Show axes on drawings".
Please could some body help me with this problem.
Solved by zcsillag. Go to Solution.
Hi zcsillag
Thank you for your reply. I matched your screen shot settings and attached the document again. I used GA front view 1:50 scale. I still don't get the same as you. See screen shot attached.
Hmm... idk ... when try to open frame ASD crash.
Im copy/paste structure in new project and all works fine.
Hi Csillag Z.
Thank you very much for the replay. I can't adjust the style on my ASD for the file that you sent me to see what the settings are that you used. I keep getting a error message. Please could you send me a screen shot of your settings.
I have a suspition that the template file that I'm using for steel may be the problem.
make new file with my template, open your file copy CTRL+C model and paste CTRL+P in new file.
Regards
Csillag Z.
Hi Csillag Z
I applied your template to my drawing on ASD, but I get the same result when attaching drawings. See below.
I have one more question to ask.
I would like to generate GA elevations of my structure on every gridline i.e. on gridlines A through G and 1 to 2
How would I go about doing that?
