AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Workframe axes not showing on layout space when attaching to document.
16 REPLIES 16
Message 1 of 17
jsaayman
1250 Views, 16 Replies
Hi
I have been evaluating ASD 2014 for a while now and the proble that I have is that when I create a GA view of the structure the grideline or axes of the workframe that is displayed in the model space doesn't appear in the layout.
I'm not sure what I'm doing wrong. When I create the workframe, I select the option "Show axes on drawings".
Please could some body help me with this problem.
16 REPLIES 16
Message 2 of 17
zcsillag
in reply to: jsaayman
Regards
Csillag Zoltán
Message 3 of 17
jsaayman
in reply to: zcsillag
Hi zcsillag
Thank you for your reply. I matched your screen shot settings and attached the document again. I used GA front view 1:50 scale. I still don't get the same as you. See screen shot attached.
Message 4 of 17
zcsillag
U have set Z in workframe ?
Regards
Csillag Zoltán
Message 5 of 17
jsaayman
Message 6 of 17
zcsillag
Uppload ASD File
Regards
Csillag Z.
Regards
Csillag Zoltán
Message 7 of 17
jsaayman
Message 8 of 17
zcsillag
Hmm... idk ... when try to open frame ASD crash.
Im copy/paste structure in new project and all works fine.
Regards
Csillag Zoltán
Message 9 of 17
jsaayman
Hi Csillag Z.
Thank you very much for the replay. I can't adjust the style on my ASD for the file that you sent me to see what the settings are that you used. I keep getting a error message. Please could you send me a screen shot of your settings.
I have a suspition that the template file that I'm using for steel may be the problem.
Message 10 of 17
zcsillag
Here my template.
Regards
Csillag Z.
Regards
Csillag Zoltán
Message 11 of 17
jsaayman
thanks
I uploaded your template and applied it to my ASD preferances, but still same result. Capture.PNG
Message 12 of 17
zcsillag
make new file with my template, open your file copy CTRL+C model and paste CTRL+P in new file.
Regards
Csillag Z.
Regards
Csillag Zoltán
Message 13 of 17
jsaayman
Hi Csillag Z
I applied your template to my drawing on ASD, but I get the same result when attaching drawings. See below.Capture.PNG
Message 14 of 17
zcsillag
Open Drawing1.dwg, im attach yestarday and use 😛
Regards
Csillag Z.
Regards
Csillag Zoltán
Message 15 of 17
jsaayman
I did what you said and it worked... thank you very much for you help
Message 16 of 17
jsaayman
I have one more question to ask.
I would like to generate GA elevations of my structure on every gridline i.e. on gridlines A through G and 1 to 2
How would I go about doing that?
Message 17 of 17
zcsillag
Make group (standard) all gridlines and generate GA.
Regards
Csillag Zoltán
”Boost
”Tips
