AutoCAD Structural Detailing General
andrea.pontiggia
Message 1 of 15 (445 Views)
Weight of the structure
445 Views, 14 Replies
09-09-2013 03:08 AM
If you use this command
to know the weight of the structure I get a value lower than what you see by creating tables with the quantities of steel.
Why does this happen?
Thanks.
Andrea
zcsillag
Message 2 of 15 (424 Views)
Re: Weight of the structure
09-09-2013 10:43 AM in reply to: andrea.pontiggia
Yes :smileyfrustrated:
Command: _RBCS_inq_group Command: RBCS_inq Choose tool [Element/Group/Assembly/Model/cOg/Connection]<Group>:Group Pick element:      Group name: Elszivo        Position: Elszivo      Multiplier: 1 Number of parts: 393      Total mass: 2534 kg
Paint area: 74.65 sq. m. Length: 5070     Width: 4065       Height: 5359
Command: Command: Command: _RBCS_inq_msize Command: RBCS_inq Choose tool [Element/Group/Assembly/Model/cOg/Connection]<Group>:Model Select elements or [ALL]:smileyfrustrated:pecify opposite corner: 433 found
 Number of parts: 253         Profiles: 57           Plates: 186       User parts: 10            Bolts: 140       Assemblies: 35           Groups: 1      Connections: 105
Total paint area: 74.65 sq. m.
Total mass: 2510 kg
Regards
Csillag Zoltán
andrea.pontiggia
Message 3 of 15 (414 Views)
09-10-2013 12:10 AM in reply to: zcsillag
so it is a bug in the program ...?
Andrea
Active Contributor
Kamikon-LK
Message 4 of 15 (403 Views)
09-10-2013 08:20 AM in reply to: andrea.pontiggia
Try untick "gross weight - plates"
andrea.pontiggia
Message 5 of 15 (399 Views)
09-10-2013 09:04 AM in reply to: Kamikon-LK
I had already tried. In reality, ASD provides a quantity of steel less than tables.
I also discovered something else, in my model I have profiles cut in half.
ASD considered in the tables (maybe a bug) profile split in half as a whole.
Can someone test this?
Andrea
zcsillag
Message 6 of 15 (396 Views)
09-10-2013 09:48 AM in reply to: andrea.pontiggia
Yess it's BUGG !!!
p1 and p2 profile same mass, but p1 cut by polyline :smileyfrustrated:
Regards
Csillag Zoltán
Active Contributor
Kamikon-LK
Message 7 of 15 (391 Views)
09-10-2013 10:19 AM in reply to: zcsillag
I think it is not a bug. In table You have gross weight of profile, and this is right value for fabricator. (To make cut element, you need a profile steel with a weight of whole element).
In window, that I showed in my last post, there should be a second option: "gross weight - profiles" - when this option would be unticked, weight in table = weight of whole structure.
zcsillag
Message 8 of 15 (387 Views)
09-10-2013 10:39 AM in reply to: Kamikon-LK
OK, and what ur answer for included below ?
made castellated beam with macro and u have in table 2xIPE mass :smileytongue:
Good luck !
Regards
Csillag Zoltán
zcsillag
Message 9 of 15 (382 Views)
09-10-2013 10:46 AM in reply to: Kamikon-LK
... " and this is right value for fabricator "  ???
Regards
Csillag Zoltán
Active Contributor
Kamikon-LK
Message 10 of 15 (377 Views)
09-10-2013 10:52 AM in reply to: zcsillag
:smileysurprised: Nice example... This shown that we need "gross weight - profile" option too, not only for plates.
You are not logged in.
Announcements
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
