AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Weight of the structure
14 REPLIES 14
Message 1 of 15
andrea_pontiggia
46227 Views, 14 Replies
If you use this command
to know the weight of the structure I get a value lower than what you see by creating tables with the quantities of steel.
Why does this happen?
Thanks.
Andrea
14 REPLIES 14
Message 2 of 15
zcsillag
in reply to: andrea_pontiggia
Yes :S
Command: _RBCS_inq_group Command: RBCS_inq Choose tool [Element/Group/Assembly/Model/cOg/Connection]<Group>:Group Pick element:      Group name: Elszivo        Position: Elszivo      Multiplier: 1 Number of parts: 393      Total mass: 2534 kg
Paint area: 74.65 sq. m. Length: 5070     Width: 4065       Height: 5359
Command: Command: Command: _RBCS_inq_msize Command: RBCS_inq Choose tool [Element/Group/Assembly/Model/cOg/Connection]<Group>:Model Select elements or [ALL]:Specify opposite corner: 433 found
 Number of parts: 253         Profiles: 57           Plates: 186       User parts: 10            Bolts: 140       Assemblies: 35           Groups: 1      Connections: 105
Total paint area: 74.65 sq. m.
Total mass: 2510 kg
Regards
Csillag Zoltán
Message 3 of 15
andrea_pontiggia
in reply to: zcsillag
so it is a bug in the program ...?
Andrea
Message 4 of 15
Try untick "gross weight - plates"
Message 5 of 15
I had already tried. In reality, ASD provides a quantity of steel less than tables.
I also discovered something else, in my model I have profiles cut in half.
ASD considered in the tables (maybe a bug) profile split in half as a whole.
Can someone test this?
Andrea
Message 6 of 15
zcsillag
Yess it's BUGG !!!
p1 and p2 profile same mass, but p1 cut by polyline :S
Regards
Csillag Zoltán
Message 7 of 15
KamikonLK
I think it is not a bug. In table You have gross weight of profile, and this is right value for fabricator. (To make cut element, you need a profile steel with a weight of whole element).
In window, that I showed in my last post, there should be a second option: "gross weight - profiles" - when this option would be unticked, weight in table = weight of whole structure.
Message 8 of 15
zcsillag
in reply to: KamikonLK
OK, and what ur answer for included below ?
made castellated beam with macro and u have in table 2xIPE mass 😛
Good luck !
Regards
Csillag Zoltán
Message 9 of 15
zcsillag
... " and this is right value for fabricator "  ???
Regards
Csillag Zoltán
Message 10 of 15
KamikonLK
Smiley Surprised Nice example... This shown that we need "gross weight - profile" option too, not only for plates.
Message 11 of 15
zcsillag
Yess !!! 😛
So when post any try it first 😄
Regards
Csillag
Regards
Csillag Zoltán
Message 12 of 15
zcsillag
Any answer from ASD Team ???
When we have "gross weight - profile" ?
Thx !
Regards
Csillag Zoltán
Message 13 of 15
KamikonLK
For three years we do not have any new options in ASD, so do not expect any exception in this case... Smiley Mad
It seems that Autodesk abandoned ASD and ASD team abandoned this forum.
Unfortunately ASD is dead software...
Message 14 of 15
zcsillag
So gogogo Tekla or Graitec :S
But idk why pay subscription 😛
Regards
Csillag Zoltán
Message 15 of 15
KamikonLK
I ask myself the same question...
but when Autodesk asks themself this question
Why we pay subscription??!!
”Boost
”Tips
