AutoCAD Structural Detailing General
Member
turandark
Message 1 of 7 (484 Views)
Weight of Plate List is not correct :(
484 Views, 6 Replies
02-08-2013 01:16 AM
Hi Everybody,
I had a problem in ADS Steel bill list. when I create bill list or plate list
, weight of the plates are not correct.  Like the image !!! What can I do for fixing ?
Please help me.
Thank you.
Valued Contributor
Priitl220
Message 2 of 7 (451 Views)
Re: Weight of Plate List is not correct :(
02-10-2013 10:58 PM in reply to: turandark
In similar situation this was a material problem. Change material of plates.
If you click on plate (in model) and check its information - you see that its weight is 0.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Member
turandark
Message 3 of 7 (443 Views)
02-11-2013 02:28 AM in reply to: turandark
Dear Priitl220,
I have tried to change material of plate when I saw this problem. But unfortunately noting is change.
Thank you for your suggestion.
Valued Contributor
Priitl220
Message 4 of 7 (438 Views)
02-11-2013 03:15 AM in reply to: turandark
Load material from different database.
If you could upload a model then I could have a look.
Member
turandark
Message 5 of 7 (432 Views)
02-11-2013 05:03 AM in reply to: turandark
Yes I can upload. Please check the attachment. It's a small part of my project. I hope that this part is enough for you.
Thank you,
Valued Contributor
Priitl220
Message 6 of 7 (428 Views)
02-11-2013 05:20 AM in reply to: turandark
Changed material to s355 and its ok.
Member
turandark
Message 7 of 7 (423 Views)
02-11-2013 06:22 AM in reply to: turandark
Thank you very muck. I did.
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
