Hi Everybody,
I had a problem in ADS Steel bill list. when I create bill list or plate list
, weight of the plates are not correct. Like the image !!! What can I do for fixing ?
Please help me.
Thank you.
Solved by Priitl220. Go to Solution.
In similar situation this was a material problem. Change material of plates.
If you click on plate (in model) and check its information - you see that its weight is 0.
Load material from different database.
If you could upload a model then I could have a look.
Yes I can upload. Please check the attachment. It's a small part of my project. I hope that this part is enough for you.
Thank you,
Changed material to s355 and its ok.
