AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Weight of Plate List is not correct :(
6 REPLIES 6
1050 Views, 6 Replies
Hi Everybody,
I had a problem in ADS Steel bill list. when I create bill list or plate list
, weight of the plates are not correct.  Like the image !!! What can I do for fixing ?
Please help me.
Thank you.
6 REPLIES 6
Priitl220
In similar situation this was a material problem. Change material of plates.
If you click on plate (in model) and check its information - you see that its weight is 0.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Dear Priitl220,
I have tried to change material of plate when I saw this problem. But unfortunately noting is change.
Thank you for your suggestion.
Priitl220
Load material from different database.
If you could upload a model then I could have a look.
Yes I can upload. Please check the attachment. It's a small part of my project. I hope that this part is enough for you.
Thank you,
Priitl220
Changed material to s355 and its ok.
Thank you very muck. I did.
”Boost
”Tips
