AutoCAD Structural Detailing General DIscussion
Furneaux
Message 1 of 5 (594 Views)
Accepted Solution
View scale and layout template
594 Views, 4 Replies
07-26-2013 05:54 AM
Hello, it's my first and I think simple question about ASD 2013 but I can't solve it. Is it possible to change view scale and layout template, views are tiny (scale 1:25) and layout A1 is huge? Drawings were made using "Automatic drawings" command.
Autodesk Inventor Professional 2013 Service Pack 1.1 Update 1
Valued Contributor
Jianna
Message 2 of 5 (555 Views)
Re: View scale and layout template
07-31-2013 05:22 AM in reply to: Furneaux
In the Object Inspector, select the view you want to change, then look towards the bottom and you'll see the scale (outlined in red in the picture). Double click on the scale, change it, then hit enter on your keyboard to apply the change.
Product Support
Jakub.Brozonowicz
Message 3 of 5 (535 Views)
08-01-2013 06:44 AM in reply to: Jianna
But it makes it different just for this exact one view only so the general move should be rather like regenaration of drawings.
Jakub Brożonowicz
Valued Contributor
Jianna
Message 4 of 5 (529 Views)
08-01-2013 11:38 AM in reply to: Jakub.Brozonowicz
Exactly. So if you'd like to change the scale for specific views so they'll default to that value in the future, go to the "Templates" tab in the object inspector, select the view, and change the scale like the photo above.
Only that specific view's scale will be changed. So if you want, for example, the top, side, and front views to all be the same scale, you'll have to click on each view and change the scale individually for each.
If this process is done in the "Positions" tab, it will apply only to that particular view in the particular instance. If this process is done in the "Temapltes" tab, any of the edited views created after that will have the new scale.
Furneaux
Message 5 of 5 (393 Views)
09-04-2013 02:53 AM in reply to: Jianna
and what about layout (main frame)? is it possible change after drawing generation?
Announcements
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
