AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Unable to reinstall ASD, please help
2 REPLIES 2
conancillo
725 Views, 2 Replies
Hello:
Something went wrong with my PC when I was installing ASD and now I cannot uninstall it and reinstall it again.
ASD does not appear on the Add/Remove programs and if I try to install ASD again it tells me that it's already installed.
Does anyone knows if I have to modifiy some registry entries to completelt remove ASD?
Aaron
2 REPLIES 2
tony
in reply to: conancillo
I had the same problem and found that if I removed the folders that weren't removed on the uninstal you are then able to instal
You ned to search the whole C drive because it creates folders all over the place
Castor63
Just go back to AutoDesk and install again, I had the same issues
”Boost
”Tips
