AutoCAD Structural Detailing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Text hight
- Highlight
- Email to a Friend
I have one problem with ASD2012. When I go to create new BOM list the text is very little, I changed the text style and the result is the same.
And when I go to modify or copy any exist deminesion the text is convert in little too. After selection the dimension and chaning from properties the hight the result is the same.
Where is the problem?
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
Re: Text hight
- Highlight
- Email to a Friend
Regarding the table texts I use textsyle with 35 pixels font height and it looks good , also it shouldn't be annotative . Same for dimension styles , but here you should use text style with 0 height , and the value you set in the dimension style will be the paper height (something between 2 and 4) . The descriptions on the other hand could use annotative text styles . It takes a lot of trial and error until you realize how the changes you made look in the generated drawings .
Re: Text hight
- Highlight
- Email to a Friend
Ok. But I don't understand why when I copy one dimension (which has good height) the program change it to little. In default generation the dimensions are good, but if you want another is imposible...
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
Re: Text hight
- Highlight
- Email to a Friend
Show screens of your dimension style and the text style you use in that dim style . I mean the settings , not how it looks in the drawing .
Re: Text hight
- Highlight
- Email to a Friend
Ok. I have resolved this, is necessary to change style of text. But I don't understand why it changed... May be, because I change the presicion of units? In first the text style were ok. And if I go to create new steel project it's ok too.
Thanks for help
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
