• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    New Member
    tolgakurt
    Template fille cannot be opened. Freeze error.
    529 Views, 5 Replies
    01-03-2011 04:19 AM
    I have downloaded and installed Structural Detailing 2010 from student community. Then, i have also registered it and now it is activated.
    The computer it was installed is a AMD Athlon X2 and it has a ATI Radeon HD4670 display adapter. The OS is Windows 7 Professional and is a stable system.
    The problem is, when I try to open Structural Detailing, it opens with the AutoCAD drawing environment well (workspace). But when I try to open a template of ASD Reinforcement or Steel; program freezes when it tries to open the template(RBCR-XXX.DWT) file.
    I have granted all the privileges of the template files to all of the users and also I have checked the path of the files. Also tried to update the program, but nothing changed.
    Please use plain text.
    New Member
    michal_miszczuk
    Re: Template fille cannot be opened. Freeze error.
    01-26-2011 11:41 AM in reply to: tolgakurt
    I've got the same problem! Could anyone tell us what to do?
    New Member
    woo4u
    02-11-2011 10:09 AM in reply to: michal_miszczuk
    i've got the same problem too, already installed SP1,2 and 3. why does it crash trying to open a template and how to fix the problem?would be nice to finally get a reply in this thread with an answer..
    02-16-2011 07:43 AM in reply to: woo4u
    Did you download the 64-bit version?
    New Member
    michal_miszczuk
    02-16-2011 10:47 AM in reply to: tolgakurt
    No, only 32 - bit version is availible on students.autodesk.com. So, still any idea how to solve this problem?
    02-16-2011 10:56 AM in reply to: tolgakurt
    That is the problem.  32 bit will not run on Windows Vista or 7.  You can set up a 32-bit virtual workstation on your machine or you can run it on an old 32-bit XP machine.  Windows 7 may have the virtual capability.  Never tried it.
