I'm having trouble creating tables, cut list, because if I have many parts, does not stop at the bottom, and then on the second sheet position does not get in the position they finished in first sheet.
You can see in the attachment I am talking about.
Please help me.
thank you
That's another problem I have, in exporting or creating a template.
The attachments are showing, after I loaded in Tables Manager, and then selected the Cut List, and then did Print Preview.
And the table at the beginning, starts well, does not break down in the footer.
I do not understand why, that table does not take away from the footer, always goes down when there are many parts, when the parts have to be distributed in 2 sheets
Jakub.Brosowicz no solution to my problem?
And also I can only export to "CSV"
To "XLS" does not write, why?
