• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Active Member
    Structural Detailing to Revit
    588 Views, 5 Replies
    06-28-2012 12:35 PM
    How do I link my Structural Detailing AutoCAD to Revit and link them so as the cad file changes it up dates in Revit?
    What I would really like to do is export Revit to AutoCAD Structural detailing. Then detail the connections and reload back into Revit.
    Please use plain text.
    Valued Contributor
    CristianLANCULESCU1367
    Re: Structural Detailing to Revit
    07-03-2012 12:44 AM in reply to: Rick
    First of all, Revit doesn't import ASD detaills.
    Second: The only workflow that really worked for me was:
    Create structure in Revit -> Analyze it in Robot -> Update Revit ->Send to ASD -> Plot.
    Revit has 2 types of connections in "Extensions":"Beam to column" and "Column end", while ASD has more then 30.
    Regards.
    Valued Contributor
    07-03-2012 09:44 AM in reply to: CristianLANCULESCU1367
    Cristian, you have worked with SDS/2 connections?
    Valued Contributor
    07-04-2012 01:25 AM in reply to: jorgeluisgdeaca
    Hi Jorge,
    I had an attempt, bu it didn't work in the first place. After that the trial has expired and I had to uninstall it. Anyway I'm receiving emails from them on a regular basis.  :smileyhappy:
    OPINION:  FOR THE MOMENT I dont think I will buy it because:
    1) Revit is not very precise for steel
    2) I'm not an expert in Revit Structure
    3) The SDS/2 is at the beginning
    4) It doesn't have localized version (Romania).
    My workflow is like this:
    I make the model in Revit, compute it in Robot, make some schematic drawings (I don't know the english terminology, but they are plans in which I show the placement of columns, beams, foundations) and then send it to ASD for detailing and shop drawing.
    Latelly I use Revit a lot, but i've started only 3 years ago...
    The Revit Structure Suite also contains ASD. What I like is:
    1) It has some macros (enough for regular buildings)
    2) It is based on AutoCad plaform (I have more experience with it)
    3) Positioning of elements and automatic drawings and annotations.
    I will not place here the inconveniences of ASD.
    Valued Contributor
    07-04-2012 06:27 AM in reply to: CristianLANCULESCU1367
    sure, I'm not an expert  using Revit too, only I want to know HOW accurately and flexible can be with steel structures, for this it's one step back to other specifics programs, but I believe this is the bussines of Revit, is an non specific program.
    Valued Contributor
    07-05-2012 12:25 AM in reply to: jorgeluisgdeaca
    Revit is very flexible with steel, but not very accurate. At least not now.
