AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Single Tubular Bracing
5 REPLIES 5
1716 Views, 5 Replies
I want to create a single piece of tubular bracing, with gussets on either end. See the attached image for the bracing centre lines. What is the best way to achieve this?
Thank you
Ryan
5 REPLIES 5
Jakub.Brozonowicz
Check the movie.
Generally it needs to be specified as NOT Crossed bracing in Diagonals tab.
Jakub Brożonowicz
Global Product Support
in reply to: Jakub.Brozonowicz
Great! Thank you for the reply.
daniel.tansey
any luck I can do this with a W beam at the middle to the cross bracing with a gusset plate on top and bottom rather than the gusset in the middle. It seems that the cross bracing tool is not what i need, but i figured i would ask.
grfkpc
hi;
i am not create this bracing in asd.
there was a way to tihs ?
Thanx.
vanvan11
in reply to: grfkpc
yes
form long time i dont use macro for bracings
”Boost
”Tips
