AutoCAD Structural Detailing General DIscussion
Valued Contributor
Priitl220
Message 1 of 4 (554 Views)
Set ASD Steel elevation mark in meters instead of mm.
554 Views, 3 Replies
02-08-2013 03:04 AM
Elevation marks are in mm (for example +4500).
How to make them show in m instead (for example +4,500)?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Product Support
Jakub.Brozonowicz
Message 2 of 4 (546 Views)
Re: Set ASD Steel elevation mark in meters instead of mm.
02-08-2013 07:51 AM in reply to: Priitl220
It is set on mm.
No way to change the unit now.
Jakub Brożonowicz
Member
Valensas
Message 3 of 4 (339 Views)
08-02-2013 05:48 AM in reply to: Priitl220
I need the same thing
Priitl220 have you ever seen anywhere elevation mark in mm? why is it set to mm and no way to change? :smileyhappy:
I have 150 drawings to change marks from 1300 to 1.300 manually now :smileyvery-happy: nice!
zcsillag
Message 4 of 4 (317 Views)
08-03-2013 12:33 PM in reply to: Priitl220
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
