Hello
I started lately to work with ASD 2013 and when i tried to save the model into earlier version of DWG i couldn't open it with the ASD 2011 or any old Autocad version, Is there any solution to that problem.
Salutations.
It is not working in this way that you expected.
DWG format version has nothing to ASD version.
Unfortunately ASD is disable to open dwg file projects created or saved in later versions.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Sounds like Revit.
Q: Why do we have the option to save a model to earlier ASD versions (2010, 2007) if it is programed not to open this files?
L.
Truly said there is no such option.
It is AutoCAD dwg file format choice. wiki
