AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Message 1 of 8
roger2566
558 Views, 7 Replies
STYLES
When i produce a drawing from a group it always comes out as a 2d wire frame how do i change it to shaded with edges or something more 3d solid looking?
7 REPLIES 7
Message 2 of 8
zcsillag
in reply to: roger2566
Can't...inactive !
Regards
Csillag Zoltán
Regards
Csillag Zoltán
Message 3 of 8
roger2566
in reply to: zcsillag
what do you mean can't inactive how do i change the settings from here?
Message 4 of 8
When I make an ISO drawing from a group I just right click on the document, then adjust style, then turn off invisible edges.
Message 5 of 8
zcsillag
"how do i change it to shaded with edges" 😛
Regards
Csillag Zoltán
Message 6 of 8
zcsillag
Why need Adjust Stye ?
Make template with invisible edges and use for ISO drawing :xD
Regards
Csillag Zoltán
Message 7 of 8
You can do shaded with edges from a group.
You would have to be in paper space and use the vport command like normal autocad. Then I guess your particular group would have to be on certain layers and then you could turn all other layers off in that particular layout.
That's the only way I know of that you could get shaded with edges, but even then I don't know if ASD would like it if you put profiles on other layers. It gets angry very easily.
Message 8 of 8
zcsillag
im say can't automatic with iso view !
Vport and other command u can made anything you like
Regards
Csillag Zoltán
”Boost
”Tips
