• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Valued Contributor
    CristianLANCULESCU1367
    [Revit-ASD] Elevation mark
    419 Views, 5 Replies
    05-29-2012 06:43 AM
    I'm exporting a model from Revit Structure to ASD (both 2013). Revit is in mm and same for ASD template.
    When creating element printouts, the elevation marks show +65 instead of +6500. Anyone has any ideea wat is wrong?
    Thank you in advance.
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: [Revit-ASD] Elevation mark
    05-31-2012 05:48 AM in reply to: CristianLANCULESCU1367
    It wrongly shows values in decimeters instead milimeters.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Valued Contributor
    05-31-2012 06:11 AM in reply to: Jakub.Brozonowicz
    It is a bug? How can I "fix" that? Is there a workaround?
    Thank you!
    New Member
    08-25-2012 11:43 AM in reply to: CristianLANCULESCU1367
    I have the same problem.
    How to get the value of elevation marks in millimeters?
    Valued Contributor
    08-27-2012 12:09 AM in reply to: Leo.ru7
    You cant. It's a "feature". Maybe in ASD 2014, because the SP for ASD2013 is still not out.
    Product Support
    Jakub.Brozonowicz
    08-27-2012 12:48 AM in reply to: lucis29
    Please be patient with regard to 2013 SP1.
    Jakub Brożonowicz
    Support Specialist
    Product Support
