AutoCAD Structural Detailing General
Valued Contributor
Ievgen
Message 1 of 5 (899 Views)
Reinforcement length in ASD 2013
899 Views, 4 Replies
10-25-2012 06:33 AM
Please help!
I want to change the maximum length of the rebar from 12m to 11.7m:
when I use command Reinforecment Elevation and try to set a single bar with a length of 40m (or smth like that) I am dealing with a dilemma: ASD tries to cut it in bars with 12m each.
Product Support
Jakub.Brozonowicz
Message 2 of 5 (889 Views)
Re: Reinforcement length in ASD 2013
10-25-2012 08:28 AM in reply to: Ievgen
MaxLength value in bar_??? database is set on 12.
(C:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Reinf)
Jakub Brożonowicz
Valued Contributor
Ievgen
Message 3 of 5 (886 Views)
10-25-2012 08:40 AM in reply to: Jakub.Brozonowicz
please specify what exact parameter I need to change. Is it possible to change with the ASD interface?
Product Support
Jakub.Brozonowicz
Message 4 of 5 (865 Views)
10-26-2012 03:25 AM in reply to: Ievgen
On interface you can only steer one bar only by MOD_BAR_LAP (Lap splices in Modify).
In database it is up to the diameter bar so many of MaxLength to change is needed.
Jakub Brożonowicz
New Member
graneeshakasunsi
Message 5 of 5 (358 Views)
04-11-2013 06:56 AM in reply to: Jakub.Brozonowicz
I want to change the max length to 6m. but it can't be done in the interface as mentioned above. couldn't either edit the source cords. pls clearly mention what should I do?
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
