• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Valued Contributor
    Accepted Solution
    Reinforcement length in ASD 2013
    628 Views, 4 Replies
    10-25-2012 06:33 AM
    Please help!
    I want to change the maximum length of the rebar from 12m to 11.7m:
    when I use command Reinforecment Elevation and try to set a single bar with a length of 40m (or smth like that) I am dealing with a dilemma: ASD tries to cut it in bars with 12m each.
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: Reinforcement length in ASD 2013
    10-25-2012 08:28 AM in reply to: Ievgen
    MaxLength value in bar_??? database is set on 12.
    (C:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Reinf)
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    10-25-2012 08:40 AM in reply to: Jakub.Brozonowicz
    please specify what exact parameter I need to change. Is it possible to change with the ASD interface?
    Product Support
    Jakub.Brozonowicz
    10-26-2012 03:25 AM in reply to: Ievgen
    On interface you can only steer one bar only by MOD_BAR_LAP (Lap splices in Modify).
    In database it is up to the diameter bar so many of MaxLength to change is needed.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    04-11-2013 06:56 AM in reply to: Jakub.Brozonowicz
    I want to change the max length to 6m. but it can't be done in the interface as mentioned above. couldn't either edit the source cords. pls clearly mention what should I do?
