AutoCAD Structural Detailing General
Active Contributor
Message 1 of 5 (674 Views)
Accepted Solution
Project Preferrence - dimensioning styles
674 Views, 4 Replies
08-07-2013 12:24 PM
Hi All,
I searched the forum on the subject and no luck.
My situation is as follow...
In Project Preferrence - Dimensioning Styles; in each category I created a style and saved (VEi...).
I lighted the style I created and hit OK (dimensioning Style dialog box), I hit SAVE (Project preferences dialog box) and then OK, but when I use the Automatic Drawing command and generate the drawing, it seems to be defaulted back the STANDARD Style. This is the case for all the Categories.
Please see attachment.
What am I doing wrong? Is there a way to select the style you created?
Thank-you,
Tee
Valued Contributor
Message 2 of 5 (670 Views)
Re: Project Preferrence - dimensioning styles
08-07-2013 12:53 PM in reply to: tpham2001
Try going to the "Templates" tab in the object inspector. Then click on each view (in my case it's the cut view from Assembly 1:5), then at the bottom you should see Section Style and Detail Style. Double click on the style name (in my case "Assembly - standard), then click on the style you want it changed to.
To my knowledge, you'll have to click on each view individually in order to change the style. But perhaps someone else knows a quicker way to change them.
I attached a picture which I hope helps.
Active Contributor
Message 3 of 5 (644 Views)
08-08-2013 08:32 AM in reply to: Jianna
Jianna,
Thank-you for the quick response and accompanying image; this helps a lot.
Unfortunately, this does not work for me. I seleected my style and went to execute the Automaic Drawings command and iit still giving me the defaulted style.
I noticed when I'm in the Object Inspector - template tab; when I changed the Dimension Style at the bottom for one template (ex Assembly 1:5), go to the next template (ex Assembly 1:10). But when I look back or click on Assembly 1:5 template, the Dimension Style reverted back to Standard.
Bug(s)?
Thanks again,
Tee
Valued Contributor
Message 4 of 5 (641 Views)
08-08-2013 09:36 AM in reply to: tpham2001
I encounter the same problem when changing the scale of each view. In order for it to permanently change (at least for me) I have to hit the enter key, otherwise it changes back just like you described.
Active Contributor
Message 5 of 5 (636 Views)
08-08-2013 10:01 AM in reply to: Jianna
Thank-you.
Yep, this enter thing works...
I guess its one of those...
ASD: You want to change style?
Me: Yes.
ASD: Are you sure?
Me: Yes.
ASD: Are you REALLY, REALLY sure?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
