AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Problem export from AutoCAD Structural Detailing to AutoCAD
3 REPLIES 3
radoslav
1452 Views, 3 Replies
Object Inspector ->Printouts --> right click  Layout1-->Save printout result fatal error
3 REPLIES 3
in reply to: radoslav
ASD Fatal error,
Hi, are you not trying to export a 2D drawing which is Projected into the sheetlayout?
Please give the steps you followed to export the model to 2d and extporting the ASD 2D drawing to Auto cAD.
Tried to work with your file. No succes.
I've made a new View and tried to add it as a Block to a Layout. It doesn't work. Something is broken in your file.
You should send it to Autodesk.
Same steps - same problem(
”Boost
”Tips
