• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    New Member
    Problem export from AutoCAD Structural Detailing to AutoCAD
    677 Views, 3 Replies
    08-15-2012 02:56 AM
    Object Inspector ->Printouts --> right click  Layout1-->Save printout result fatal error
    Please use plain text.
    Valued Contributor
    HulelaG
    Re: Problem export from AutoCAD Structural Detailing to AutoCAD
    08-15-2012 06:01 AM in reply to: radoslav
    ASD Fatal error,
    Hi, are you not trying to export a 2D drawing which is Projected into the sheetlayout?
    Please give the steps you followed to export the model to 2d and extporting the ASD 2D drawing to Auto cAD.
    Valued Contributor
    CristianLANCULESCU1367
    08-16-2012 01:08 AM in reply to: HulelaG
    Tried to work with your file. No succes.
    I've made a new View and tried to add it as a Block to a Layout. It doesn't work. Something is broken in your file.
    You should send it to Autodesk.
    Valued Contributor
    10-10-2012 07:09 AM in reply to: CristianLANCULESCU1367
    Same steps - same problem(
