• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Active Member
    VasZiog
    Plate thickness variable
    325 Views, 4 Replies
    08-03-2011 06:37 AM
    Is there any variable for the plate thickness?
    Thanks in advance!
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: Plate thickness variable
    08-03-2011 07:45 AM in reply to: VasZiog
    Do you mean the variable kind of thickness on panels?
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Active Member
    VasZiog
    08-03-2011 08:38 AM in reply to: Jakub.Brozonowicz
    i am refering to steel plates!
    Basically my goal is to enter in the printouts the thickness of the plates. i found the variable for part length, material... etc. but i can not find which is the variable for the plate thickness.
    Thank for your qucik reply
    Product Support
    Jakub.Brozonowicz
    08-04-2011 01:48 AM in reply to: VasZiog
    There ar no dedicated variable for such value like plate thickness.
    %%Name is composed from data like thickness and width of plate and is a variable itself without previous level of variables like sizes what you asked.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Active Member
    VasZiog
    08-04-2011 05:00 AM in reply to: Jakub.Brozonowicz
    i hope maybe in next version they add it!
    Thank you very much for the information. You saved me lot of searching!
