• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Member
    Accepted Solution
    Plant 3D or Revit talk to Structural Detailing??
    745 Views, 4 Replies
    08-27-2012 02:33 AM
    Do someone konw how Plant 3D or Revit talk to Structural Detailing??
    I tried .dwg or .dxf files in Detailing, which are exported from Plant 3D or Revit. However, the member properties (the size, etc.) are missing.
    The Structural Detailing introduction tells: " A structural Steel model created in Autodesk Revit Structure can be exported to AutoCAD Structural Detaling via CIS/2 file to complete all of the steel connection modelling and detailing, and automaticlly creat fabrication shop drawings.".
    I don't know what the CIS/2 file means what. Can someone help?
     Regards
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Plant 3D or Revit talk to Structural Detailing??
    08-27-2012 04:28 AM in reply to: xaut818
    For subscription customers, there is a Revit Extensions pack that includes an Export to Structural Detailing.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Contributor
    08-27-2012 05:07 AM in reply to: xaut818
    First: download Revit Extension from Subscription or any place.
    After install: Revit, Extensions, ASD....then you must designate which sections will be used
    See below the attached
    Member
    09-03-2012 09:15 PM in reply to: jorgeluisgdeaca
    Thanks for ur help
    Valued Contributor
    09-04-2012 10:40 AM in reply to: xaut818
    you're welcome
