• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Valued Contributor
    StefanoPasquini6790
    Accepted Solution
    Personalized bill of material
    550 Views, 8 Replies
    05-25-2012 10:37 AM
    Hello, I need to create a bill of material such as that found in the annex, I tried manytimes but I can not. Some of you can help me?
    Could you explain how to use an .xlt excel file as a basis for creating the list of materials?
    thanks a lot
    Stefano Pasquini
    Please use plain text.
    Valued Contributor
    CristianLANCULESCU1367
    Re: Personalized bill of material
    05-29-2012 06:45 AM in reply to: StefanoPasquini6790
    If you could translate thoose in English, maybe we can tell you what you can and what you cannot add in you table.
    Valued Contributor
    StefanoPasquini6790
    06-04-2012 12:26 AM in reply to: CristianLANCULESCU1367
    HI,
    i'm sorry for my delay, but i had any problems in last days. Attached below the excel file with the english translation of the required property for my personalized bill of material.
    Regard and thank you.
    Valued Contributor
    StefanoPasquini6790
    01-10-2013 02:39 AM in reply to: StefanoPasquini6790
    Hi everyone,
    I've resolved with a VBA Macro for Excel, that transform the original BOM in a required one. If someone is interested to resolve the same issue, or a similar one, I can help you, obviously for free!
    Greetings
    Active Member
    01-22-2013 03:48 AM in reply to: StefanoPasquini6790
    Hello
    I have the same problem, how did you manage to solve?
    Valued Contributor
    StefanoPasquini6790
    01-22-2013 05:40 AM in reply to: silvionogueira
    if you can better specify me what you really want to have in your BOM (cut list), I can tell you if I can help you.
    Greetings
    Active Member
    01-22-2013 07:42 AM in reply to: StefanoPasquini6790
    What will I use most, is cut list of plates and profiles.
    The precise position, quantity, profile, length, weight and area
    In short, it's like I show in the appendix, the biggest problem that I am showing is that the table does not interrupt the Rhodope, and when it goes to the second sheet, there will be continued last position of the first sheet should be hidden behind the header
    Valued Contributor
    StefanoPasquini6790
    01-22-2013 07:50 AM in reply to: silvionogueira
    You can't plot in excel the table? Only in this case I can help you!
    Active Member
    01-22-2013 08:14 AM in reply to: StefanoPasquini6790
    I can export to the format "csv" but header is unformatted
    I do not know is to use the template.
    Can you explain to me how to use template, export or straight?
    When I export to "CSV" is thus, as I show in the Annex.
    Anular edições
    Alpha
