AutoCAD Structural Detailing General DIscussion
Active Contributor
jorge.lopera
Message 1 of 2 (313 Views)
Accepted Solution
PIPES- FLANGES- BOLTS OUT OF STEP
313 Views, 1 Replies
03-02-2014 09:20 AM
Trying to use Pipes-Flanges connection with DIN pipe size appears the bolts out of step.
I have tried too the Pipes-anchored, and doesn`t appear the holes at the part.
Is there any limitation with this command?
Please help.
Regards
Technical Specialist
Nexsys de Colombia
Product Support
Jakub.Brozonowicz
Message 2 of 2 (250 Views)
Re: PIPES- FLANGES- BOLTS OUT OF STEP
03-07-2014 04:37 PM in reply to: jorge.lopera
Could you please try to check if you defined the Radius value correctly (not Diameter)?
Please check the video. http://screencast.com/t/TnOFA3vvXY
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
You are not logged in.
Announcements
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
