• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Valued Contributor
    Opening ASD 2010 Steel drawing with ASD 2013 - Fatal error
    448 Views, 7 Replies
    12-17-2012 12:39 AM
    Should I be able to open ASD 2010 steel drawing with ASD 2013 version?
    ____________________________________________
    If you find my post useful give me Kudos. Thank you!
    If my post solved your problem, accept it as a solution.
    Please use plain text.
    Valued Contributor
    Re: Opening ASD 2010 Steel drawing with ASD 2013 - Fatal error
    12-17-2012 01:13 AM in reply to: Priitl220
    Of course. The other way arround is not possible.
    Valued Contributor
    12-17-2012 01:30 AM in reply to: lucis29
    Have you tried it yourself?
    For me it causes fatal error.  I have tired with two different drawings.
    I can not post the drawings, as they contain sensitive information.
    And I cannot produce any other sample file, as I do not have ASD 2010 installed.
    P.S. The other way around .... was not the question.
    Product Support
    Jakub.Brozonowicz
    12-17-2012 03:57 AM in reply to: Priitl220
    I think sometimes it happens but please try to share the file.
    We have abilities to check it closer and possibly fix.
    BTW is 2010 version file saved on priintout or model tab?
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Valued Contributor
    12-17-2012 04:00 AM in reply to: Priitl220
    Yes. Off course I've tried. Otherwise I wouldn't have answered.
    Try to open the back-up file.
    Product Support
    Jakub.Brozonowicz
    12-20-2012 08:24 AM in reply to: lucis29
    Finally it was solution by opening with recover in 2011 and saving there.
    Next attempt of opening it in 2013 finishes successfully.
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Valued Contributor
    12-21-2012 07:59 AM in reply to: Jakub.Brozonowicz
    So, that means ASD2011 is the most stable and the best version? I still vote vor ASD2012 as beeing the best until now.
    Product Support
    Jakub.Brozonowicz
    12-21-2012 08:31 AM in reply to: lucis29
    This solution accepted is just incidental - in such case only.
    General conclusion about stability is rather unjustified.
    But I can confirm that most of all examples are not easy to open in 2013.
    Jakub Brożonowicz
    Support Specialist
    Product Support
